standover height
3/24/2020 2:56 PM
I'm really not sure what the advantages and disadvantages are of higher or lower standovers. I'm not sure what my 2014 Haro 500.1 frame's actual standover is. The Haro website says 21.5" which is ridiculous, I'm on a 21 inch frame I don't know how that would even be possible. I'm building up a new custom actively, and I was wondering whether to choose a tall or a short standover frame. I'm not super short 5'11" but I am somewhat leaning towards a shorter standover. I'm not sure what the cons of a short standover are, but I like the idea of leg room, and having more space during big hops. I need more information though. Hopefully you guys can help.
website: https://archive.harobikes.com/bmx/2014-freestyle/500-1-2014
3/24/2020 3:11 PM
It's really personal preference do you like the look of lower or taller ? It doesn't really change anything else besides lower being easier for foot tricks and higher more barspin type stuff but you can even bar etc with a lower so.
3/24/2020 3:47 PM
The top tubes are 20.5” and 21”, it’s the seat tube length that the standover refers to.
A typical height is around 8.5” these days. Like Cell said, it’s more of an aesthetic factor than a performance one, but it will change a couple things. I recall Stranger made a frame that had a 10” standover, I think it was Caleb Quanbeck’s sig. model. But then there are super short standovers that go below 7” tall.
If you like a bit of height to your seat, but don’t like the look of running a seatpost miles long, get a taller one. If you run a slammed seat and like it low, picking a shorter standover won’t hurt.
I run a low standover at 7.4” and slam my seat, and it helps with my can-cans and footjam whips, it was a noticeable change when I came from a 8.75” standover on my old frame.
Instagram: @scootereyn
3/24/2020 5:14 PM
Personally, stand over is important to me. As someone else mentioned, 8.5" is a middle ground, and it feels pretty good. I rode an 8" SO for a long time. I'm not a huge fan of a really low SO, so 8" is the lowest I'd go. I rode a 7.25" for a while, and I did not care for it much. But it's all personal preference, and you could love a 7" SO.
A lower standover will be less stable in the air, but easier to manipulate side-to-side, and will provide more clearance for any trick involving raising at least one foot/leg over the top tube.
A higher standover is more stable in the air, but doesn't lean as easily as a shorter SO would. They provide less clearance for tailwhips, can-cans, ect.
The standover on that Haro appears to be between 8.5" and 9".
If you can try a bike/frame with a lower SO it could help with your decision.
I'd say if you want to try a short SO, 8" could be a good compromise, being short, but not too short.
3/24/2020 5:39 PM
I run a 7.25 stand over frame. I love the look and I feel tailwhip are personally easier for me. I’ve always ridden an 8.5 stand over but with a 11.5 BB it’s still pretty low compared to a 8.5 with like an 11.8.
3/24/2020 5:40 PM
So basically there is some other things that you need to take in also
3/24/2020 6:02 PM
Agree, BB paired with SO is very significant.
3/24/2020 6:36 PM
High standovers are a pain in the ass for can can maneuvers
3/24/2020 7:16 PM
This don't make a lot of sense, when primarily park frames have the lowest standover and that is what most big air riders seem to be using for flying out of mega ramps into the stratosphere.
I'd guess short standover gives the bike an overall lower CG therefore making them more stable for high speed use.
3/24/2020 7:31 PM
The mega ramp guys that ride wizards are a 11.8 BB which is pretty high for my taste. I think it’s a 8 or 8.25 stand over.
Saw Morgan wade recently doing bmx shows and was talking to him about his new sig frame. It’s freaking long and tall.
3/26/2020 1:13 PM
Edited Date/Time: 3/26/2020 1:13 PM
I prefer the look of a higher stand over. But I would imagine it's harder to get your feet over when doing tailwhips. But people do....
Mine is like 8.5 and looks low to me. But then when I measure my BB height it's at 12". That seems high. So I got a lower than I want top tube and a higher than I want bottom tube. LOL. If I get smaller tires that will help the Bottom Bracket height get a little lower though.
3/27/2020 3:26 AM
How are you measuring the BB height though? Cause it might measure as 12" from the floor but that isn't likely the actual BB height of your frame on paper.
Correct way to measure is first measure height of the center of rear axle to the floor. Take that measurement and minus it by 10" (half of true 20" tire diameter) and keep that number in mind. Then measure to center of crank spindle, minus it by the amount in the previous axle calculation for the closest to spec BB height of your frame.
3/27/2020 8:13 AM
Park riders use low SO because it's easier to do tricks like turndowns, tables, foot jam and tailwhip stuff, all of which regularly put your leg in contact with the TT. The lower SO is out of the way so it makes it easier to do those tricks without banging their foot or leg on it (though they are still possible with higher SO). It also makes the bike.lighter and because its mass is more concentrated, its easier to throw around in the air.
Some folks say a higher SO makes the bike more stable but I really believe that's just a mental thing as it really just makes it heavier and creates more drag when its moving and that could be what they're experiencing and referring to. I really don't think it makes a bike perform better or worse, its more about rider comfort.
3/27/2020 8:37 AM
Somehow you lost me. All I know is that when I have the bike standing vertical, and I take a tape measure and measure from the floor to the center axis of the crank, it's 12". Your calculation makes me think it would be 10". But I don't think I'm following your formula properly.
3/27/2020 12:30 PM
You sound about right, and not everyone’s will be 100% on-the-dot. Plus, it depends what tire size you run.
For example, a 11.8” BB will technically sit lower on 1.95” tires compared to 2.5” tires. But like street said, calculations for these things are done with the base value of 20”, the diameter of a BMX wheel.
3/27/2020 12:59 PM
Flatland typically has a lower standover than park but also not really for airing either.
-Sheldon on Adam22
"The only future for BMX"
-jbales on mafiaBIKES
-adamnmexican
3/27/2020 2:16 PM
Measure the rear axle height, minus that number by 10 inches. Then measure the crank spindle height, minus that number by the previous answer of the axle calculation.
Here like this;
My rear axle height is just on 10.5" (minus 10 = 0.5)
My crank spindle height is 12.35"
12.35 - 0.5 = Actual BB height
Therefore the frame is technically 11.85" BB (not the 11.5 the bike brand thinks China welded together)
3/30/2020 10:37 AM
Edited Date/Time: 3/30/2020 10:38 AM
OK. Thanks for the formula. Just measured. I got 10-5/8" at the rear axle and 12-1/4" at the crank....
So lets see... axle height minus 10 equals 5/8". 12-1/4 minus 5/8" would be...…. 11-5/8"... I think.
Dang, mines lower than yours by a hair. LOL.
Yeah, my tires are fat. I just measured them with a caliper over the weekend and my rear tire is at 2.48 and my front is at 2.46. Yowza. I have them pumped up to almost exactly 60. I think the front is right at 60 and the rear was 58. Or vice versa. I knew I had one of the right on and the other one was just under and I said close enough. That was like a week ago.
3/31/2020 3:11 PM
So your frame most likely has an 11.6 BB height, common for many frames to be around 11.5 - 11.7 these days.
It's a more significant difference than you think though, got a buddy with a Dak frame (11.6) and it just feels low and odd for me being used to the snappier feel of the high BB, which I think is partly because of the angle of the CS.
3/31/2020 3:20 PM
4/1/2020 10:18 AM
Well Shiver me timbers. Learn something new every day. I thought mine was actually high but it's just my tires. LOL.
