stem
2/9/2014 9:12 AM
i just got the Odyssey CFL stem theyre awesome but i cant put them on my forks
i ride stock forks from a sunday aaron ross AM complete
I try to put the stem on the forks like it should be (it is a front load) and it just wont fit
however when i flip it it fits
How can I fix this problem?
YO
2/9/2014 9:18 AM
picture? do you have any spacers on the forks or anything like that?
2/9/2014 9:20 AM
nope I don't have any spacers nor pictures
YO
2/9/2014 9:25 AM
I think you need to loosen the pinch bolts. They're the ones on the sides.
2/9/2014 9:29 AM
Edited Date/Time: 2/9/2014 9:29 AM
no i mean when they are loose and i try to put the stem on the actual forks it wont go onto the forks
i think the problem may be with the forks because they are stock forks but im not sure
YO
2/9/2014 9:31 AM
Some stems I actually had to tap them on with a Rubber Malet, then it fit just fine.
2/9/2014 9:33 AM
They might be defective, if they fit upside down but not right side up then its probably a manufactures defect, take it to a shop to make sure
2/9/2014 9:35 AM
Edited Date/Time: 2/9/2014 9:36 AM
If it doesn't fit you might have gotten a bad stem or maybe your steerer tube is alittle bent
Murica bike check
2/9/2014 9:46 AM
Probably a defective stem. My friend left his bike at the park one day and I flipped his bike. Put his cranks on crooked, his front wheel on backwards, turned his seat backwards, flipped his stem around, put his bars on backwards abd upside down, forks backwards, etc.
One thing I couldnt do is put his stem on upside down. It just wouldn't go on that way. So your stem probably got machined upside down causing this problem. I would call whoever you ordered it from or Odyssey and get it replaced
2/9/2014 9:49 AM
thanks for the help guys but i live in Bulgaria and replacing it is going to be hard sad
I will just go to my local bike shop and see what can I do (y)
YO
2/9/2014 9:52 AM
You can take a round file and file it lightly until it fits if replacing it will be that much of a problem.
2/9/2014 10:53 AM
More lube and brute force.
2/9/2014 11:57 AM
but then getting it out will be hard :D
YO
2/9/2014 11:59 AM
Remove the pinch bolts and thread the bottom one in from the other side. Put a coin in the slot so when you tighten the bolt it spreads the stem slightly so you can get it on the fork. That should work unless the stem is really messed up.
Refs buying: bmxtru13(2), ecuadevil
2/9/2014 12:40 PM
You wont even need a tenth of a turn with the coin method so be careful or you will fuck up the stem.
