stripped crank bolt
12/27/2013 5:07 PM
I bought the bike yesterday and one side of the crank bolts are stripped its almost completely round. But not quite Photo
any help would be great thanks
12/27/2013 6:13 PM
How did that happen? Use the right size Allen key next time.
12/27/2013 6:18 PM
Dont assume I didn't use the right Allen key because I did. It came a little bit stripped from the store
12/27/2013 6:22 PM
Take it off with a little bigger allen key see if it works and get new bolts from the hardware store asap
I'm gonna need bigger bars
12/27/2013 6:25 PM
Yeah I only have a 6mm on me right now I'll have to grab a 7mm tommorow
12/27/2013 6:38 PM
Take it back to the store you got it from and have them take it off for you
Murica bike check
12/27/2013 6:44 PM
parts don't come stripped from the store. you probably installed it and the allen keeps popping out. thus wearing out the bolt. treats what it looked like to me
Old bike VVV
California Living
12/27/2013 6:51 PM
Why would you need to tighten the cranks if you purchased it yesterday?
Is it a used bike?
12/27/2013 6:54 PM
Is it a used bike?
Idk maybe I'd like to check over the bike my self? Self maintenance yenno
12/27/2013 7:03 PM
I applaud you wanting to learn to work on your bike. This may be a good lesson. Use the correct size tool and be careful when using it. Even the correct size nut/bolt/tool can get stripped over time.
If that was a brand new bolt, you clearly put a LOT of force on it. Make sure you know what way to turn the bolt can help prevent this too.
A good set of tools is a nice investment.
For my bike, I like just the tools I need.
4, 5, 6, and 8 MM allen.
pedal wrench
large crescent wrench (learn to use it or you'll fuck every nut you touch with it)
Good tire tools
Good grease
If you have questions about working on your bike, ask. It can save you a lot of head ache
12/27/2013 7:08 PM
pnj wrote:
I applaud you wanting to learn to work on your bike. This may be a good lesson. Use the correct size tool and be careful when ...more
Thank you. I'll have to invest in a good tool kit I already have a pedal wrench and grease crescent wrench I just need some better Allen's.
12/27/2013 7:21 PM
Buy an Allen key slightly bigger then that then hammer it in their take out the bolt and youl probably need a new bolt cause that one and the Allen key will be a write off
12/27/2013 7:24 PM
eskimojay wrote:
Buy an Allen key slightly bigger then that then hammer it in their take out the bolt and youl probably need a new bolt cause ...more
Already have 2 titanium ones ready to go in. I'll have to find a 7mm Allen wrench tommorw since the 6mm doesn't work
12/27/2013 7:36 PM
7mm will be too big, try 1/4 or 6.5mm.
OR, drill two holes beside the allen slot, on different sides, and use something like two allen keys to loosen it off.
12/27/2013 7:58 PM
OR, drill two holes beside the allen slot, on different sides, and use something like ...more
1/4 sae is to big I'll have to go with a 6.5mm
12/27/2013 8:00 PM
1/4 and 6.5mm are practically the same size.
12/27/2013 8:21 PM
take off the opposite side crank , then on the stripped side take off the pinch bolt then hammer out the spindle
12/27/2013 8:25 PM
Could I take off the non stripped side.(drive side) then undo the pinch bolt and just screw the spindle off? Seems like that would work ?
12/27/2013 8:27 PM
11cole11 wrote:
Could I take off the non stripped side.(drive side) then undo the pinch bolt and just screw the spindle off? Seems like that ...more
ill make a video for u brb
12/27/2013 8:35 PM
I got it man. Thanks so muchal after knocked the spindle out the bolt just came loose.
12/27/2013 8:49 PM
Hooray!
12/27/2013 8:54 PM
feeble_to_face wrote:
parts don't come stripped from the store. you probably installed it and the allen keeps popping out. thus wearing out the ...more
And the bike shop her isn't a professional bike shop. There's only 1 person that works there and 1person that builds the bikes and yeah he coulda stripped the bolt accidents happen
