tight ass pedals
5/10/2014 12:42 PM
does anybody know which way you need to turn the spanner to get the pedals off.
Also i snapped a spanner doing it and it had barely budged is it rusted on or is it just super tight
5/10/2014 12:49 PM
Anti-clockwise for the Right side pedal, Clockwise for the Left. They may well be stuck on, if so you just have to keep trying. I ended up having to use a 4ft tube as an extension to the spanner once, I broke 3 spanners but it worked. Next time you put pedals on make sure you grease the threads, and do the same every time you put pedals on.
5/10/2014 1:24 PM
WD40 the pedals it and then hold the crank with 1 hand while tightening/loosening the pedal with a wrench. If it gets loose then your good if it tightens go the opposite way lol.
5/10/2014 1:30 PM
I hate taking pedals off! Always make sure you turn the wrench toward the back wheel when you take pedals off. The left pedal has backwards threads.
IG @curtis_cantbmxwell
@kirolling
