tips for jumping a hip
10/23/2015 8:58 AM
I'm from the old school where hips weren't as prominent as they are today. I have been practicing on a small hip but I just can't seem to get the landing down smoothly. I either land crooked on the landing (as if the jump was not a hip), or I land correct on the landing but my weight is in a weird shift.
I'm assuming you cannot just rotate your bike mid-air, since your trajectory will still be going straight. Do you guys carve the lip? Maybe I should be focusing on the landing and not the lip before hitting it? Should I shift my weight before hitting the lip?
Thanks.
10/23/2015 10:26 AM
Go straight-turn in the air-best way to do it
Da Laird
unfuckwithable ill
10/23/2015 10:51 AM
I come at hips at an angle near the top. Essentially on a 90 degree hip I come at the top around 45 degrees to make sure I have the ability to land decently, then I treat it like a straight jump. OR if I am spinning I try to land around 45 degrees from where I started angle-wise if that makes sense.
10/23/2015 10:59 AM
Make sure to go off the top of the hip and bounce both wheels off coping like airing a quarterpipe , carving always takes momentum away and youl have less amplitude the more you carve
10/23/2015 11:14 AM
Also just ride it a LOT. It will take practice to be able to boost the crap out of it and still land ok/with a solid pump. Learn to pump over it slowly, then apply the same motions to it as you go faster and faster.
What also helped me was nose bonking over the top of the hip, basically jump low and put your front wheel down on it, keeping your front wheel aimed where your momentum has you going will be very helpful.
10/24/2015 12:12 PM
Motowhips help
-HardBMX_Tim
10/24/2015 1:05 PM
Thanks guys.
Yeah motowhips. Thats next.
