Hello guys, for 2 days I have a problem with my rear tire. After 20-40 minutes of riding is getting out of the rim. What I should do?
Make sure the bead is seated in the rim properly and pump the tyre slowly and keep checking for raised spots on the tyre near the bead
This, and also make sure the tire pressure is around what the tire has for a maximum pressure.
Mine are like 110 or 100 PSI and I run around 80.
Now if your tire says anything under 65 PSI, MAX IT OUT.
