turning RHD into LHD?
5/31/2012 9:00 PM
Edited Date/Time: 5/31/2012 9:01 PM
i've heard it's possible to do with hubs but what about cranks? got any tips/how to on both? and also what hub guard would fit a premium subway stock front hub? i don't really want a big g-sport gland on my bicycle
Instagram= suckmydeeeck
Tumblr= http://benkingyo.tumblr.com/
5/31/2012 9:26 PM
it wont work with any hubs
for cranks if there in no dual crank bolt hole some people switch the whole crank arm system around and swap out the pedal bodies
5/31/2012 9:31 PM
yea, it depends. what kinda hub and do you have?
RIP 71 N
RIP Randy Taylor
Shadow/Subrosa
Tumblr | Instagram | Digits - (407) 655-6998 | Email - kyzem.leahcim@yahoo.com | Xbox - eleswun
5/31/2012 9:42 PM
Theres a way to do it but you have to take apart the ENTIRE hub. i would just buy the stuff
| Temper Tantrum | Instagram | Tumblr | Xbox - Slow Miatas |
5/31/2012 11:17 PM
that sucks, i don't having any money. i grind on my right and i don't wanna bend my sprocket any more the it is.
5/31/2012 11:42 PM
I was in the same position once. Then I got a Mutiny Ethereal sprocket, 7mm thickness!
Your best bet is to get the plastic Primo DSG and and thicker and stronger sprocket e.g. Odyssey MDS.
6/1/2012 12:10 AM
get a pimp disc... its alot cheaper
skooter... dont be a pussy
6/1/2012 12:29 AM
pimp disc? aha
6/1/2012 4:47 AM
6/1/2012 5:00 AM
Yea, the Gsport Ratchet, Eastern Birectional, and an Alienation one can be swapped.
As to what you said about cranks, they will still unthread from the arms. If the OP had LHD compatible cranks, no issue. If not, he should invest in some.
6/1/2012 11:29 PM
this^
