what should i do?
2/14/2010 7:01 PM
i want my bars to spin faster and i tried oiling my headset and forks but they still spin slow
its always sunny in Arizona smile
== l)_.._(I==/__/ ====== pika pika
==(o^_^o)=Z__7=====
==("____")Z7=======
haters hate. get use to it .
ON 7/12/10 I GOT TO TALK TO AARON ROSS. I WILL ALL WAYS REMEMBER BEING THAT STOKED.
2/14/2010 7:03 PM
throw fastersmile
2/14/2010 7:04 PM
Edited Date/Time: 2/14/2010 7:04 PM
you might be tightening your compression bolt too much. or if you have an unsealed headset your bearings might be crushed
crystal meth
2/14/2010 7:12 PM
this as well
2/14/2010 7:15 PM
i have a integrated head set
==(o^_^o)=Z__7=====
==("____")Z7=======
2/14/2010 7:16 PM
bearings could still be broken. or your tightening your compression bolt too much. tighten it just enough so theres no play
crystal meth
2/14/2010 7:17 PM
dont oil bearings. oil pretty much ruins the grease in the bearings. yyou only grease bearings. never oil
refs: justridebmx, four, kingpin, Alex_DeWitt, Michael_Howard, bmxrider000, TokenBMX(x2)
member of the week 2/22/10 - 2/28/10
2/14/2010 7:21 PM
i had the same problem, i had the compression bolt to tight, its trial and error, if its too loose you will have play but if its to tight they wont spin smoothly
wen you say "i oiled my head set" do u mean like WD-40? cus that wont work, u gotta take it apart and use thick grease like pensoil or something
refs: hcpmichaek ; 605 ; ridelife92; Mduda005; iridebmxeveryday; Pcoco; Brenden1207;Wolfen; wethepeoplearepurple; streetrat420; bstick; spikez5; aw1234512
call or txt me for parts only
732 325 8107
2/14/2010 7:27 PM
actually i was out of wd 40 and i was tryin to learn x ups so i used engine oil i know it wasent the best idea but it did work for a while then it got stiff again
==(o^_^o)=Z__7=====
==("____")Z7=======
2/14/2010 7:29 PM
actually i was out of wd 40 and i was tryin to learn x ups so i used engine oil i know it wasent the best idea but it did work ...more
buy phil wood or finish line grease
2/14/2010 7:31 PM
i suggest you take everything apart, clean everything up real good, inspect the bearings and if they are good put it back together(with grease) and do the trial and error, its really annoying
732 325 8107
