3/8 onyx hubs in box forks
12/11/2018 3:43 PM
I'm installing 3/8 onyx hubs in new box x2 forks with the 10mm adaptors. Should I have to spread the forks apart a little to slide the wheel in or not. Seems like too tight of a fit
12/14/2018 6:37 AM
Edited Date/Time: 12/14/2018 6:39 AM
You should not have to spread the forks... the ones I have had don't any flex. Anyhow just make sure to have the correct wrench to be able to turn the inside nut... otherwise you could wind up with everything so tight the wheel has too much friction when rolling.
