360 help
2/15/2014 9:59 PM
I keep spinning wide when I try 360's on a flyout. I've landed it a few times but landed wide. anytips to spin straight would be helpful than
2/16/2014 11:59 AM
Keep your head turning and tuck your knee. DOnt carve more than 70grades.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
2/16/2014 6:30 PM
Edited Date/Time: 2/17/2014 1:26 AM
Thanks ;-). I carve a bit to the right which is the way i spin. So when u mean carve do u mean to turn to like the left then swoop it around to the right????????
2/17/2014 10:13 PM
Im working on 3s myself trying to get out of doing 270 taps. Carving is more of doing a slight pivot on the back wheel as the front is coming up. I see some riders quickly turn the bars the opposite way before whipping it around and it gives them more momentum for the spin. whatever works for u long as ur not carving too much and making it look more like a 270. Most importantly u wanna tuck at 180 and hold it all the way around
2/18/2014 1:20 PM
lbour26 wrote:
Thanks ;-). I carve a bit to the right which is the way i spin. So when u mean carve do u mean to turn to like the left then ...more
yeah, kinda like turning a bit to the opposite way that you spin, then turn hard to the other side, maybe you should turn a bit more, pull your fornt end as high as you caan, then tuck your knees.
RIDE OR DIE
THE ROUTER
2/20/2014 2:30 AM
Thanx guys went out and landed a few. getting them straighter ;-)
2/21/2014 6:11 PM
goood!
RIDE OR DIE
THE ROUTER
