Rookie question i'm sure, but needs to be asked.
When swapping from Plastic sleeve, to raw peg, there is a set of large washers / spacers in between the peg and drop out.
I put the sleeves on last night for a while, and wondered about using the spacer.
Does anyone know if you're meant to remove them when using the plastic sleeve? - because I have done, after bending one of them in between the sleeve and dropout after tightening axle bolt.
yours in anticipation and mild stupidity
UG.
