Applying pegs
9/6/2017 5:02 PM
How do u apply pegs that don't have threading ?
9/7/2017 11:30 AM
Most pegs are not internally threaded. They are through drilled to fit on a male or female axle in the sizes of 3/8 or 14mm. (front and back axle size)
Some pegs are universal and are drilled to fit a 14mm axle but include a 3/8 adapter so you can use it on either front or back.
You just undo your axle nut. Slide the peg over the axle and rethread the nut back on and tighten.
Hope this helps. This forum isn't particularly helpful in this section as it seems everyone just posts in general bmx talk.
Good luck.
