Bars keep moving no matter what
7/8/2019 9:54 AM
I sanded inside of the stem, i sanded the bars, i put a piece of rubber in there, tightened it down all the way i can in a x pattern, and it still moves when i land from a hop. I'm hopeless right now, only thing i can think of is either to buy new screws or whole new stem.
7/9/2019 6:37 AM
It’s probably the bars. Once they’ve crushed a little they’ll always slip
10/8/2019 8:55 AM
I have a great solution to this if you’d like to hear and try it out.
The absolute best way that I’ve found to overcome this issue is to just cut a pop can apart until you can just cut a small piece of the aluminum off of it. Then just wrap your bars with that cut piece of aluminum and reattach to the stem. Works every time. I got this tip from the motorcycle community and it’s saved everyone that I’ve showed this trick to. Hope this helps!
