Barspin help
10/9/2018 8:51 AM
Trying to learn bars but every time I throw the bar, the bike falls to the side and I cant seem to pinch the seat with my knees correctly. If you have any tips they will be greatly appreciated.
Instagram - https://www.instagram.com/_eli.173_/
Bike Check - Coming Soon!
Refs - dikdiamond
10/10/2018 6:01 AM
Some people say to pinch the crank arms with your feet. I found you can lean the seat against your calf to keep the bike more upright too though. But I haven't done a barspin for over 10 years so.......
10/10/2018 6:07 AM
what do you mean by leaning the seat up against your calf
Refs - dikdiamond
10/10/2018 10:26 AM
Forget about pinching the seat. Just get your feet closer to the crank arms, and focus on throwing the bars in a good circular motion.
The main reason your bikes moves around when you barspin is if you don't throw the bars in a perfect circle relative to the fork axis. If you throw slightly off, the part of the force not tangent to the fork axis will be wasted and actually cause your bike to move.
Technically if you throw in a perfect circle you barely need any force to do a barspin
10/10/2018 4:49 PM
Fatalize wrote:
Forget about pinching the seat. Just get your feet closer to the crank arms, and focus on throwing the bars in a good circular ...more
Thanks for the help!
Refs - dikdiamond
12/19/2018 7:18 PM
Sometimes I feel the bone going to the side , but then I catch and it straightened up , I had this problem too , hurt my ankles a lot , turned out I was doing an x up then throwing instead of taking my left hand off about t bar
