Cant 180
5/29/2017 1:03 PM
I know it says I can't but I can.. Kind of. I sometimes do an 180 but 99% of the time I don't. I do everything I'm supposed to do except for the Turn your head part. I go to do it and instinctively I turn it back
5/30/2017 11:46 PM
You don't really need to turn your head for 180's. A lot of people make the mistake of carving too much, try to carve less, and aim to over rotate a bit
6/24/2017 3:17 PM
yeah as steve said you dont need to turn your head, i dont really even do it for some 360 tricks like a 360 tail tap. But thats flat.
What I did was carve like crazy, I almost over did it a few times but what i noticed is that it takes all your control away and doesnt set you up well for a fakie. So if you can bhop between 1.5-2 feet then you should be good, because if you want to be more accurate in your landing then you need to put more focus and power in to the bunny hop. And yes, over doing the spin does help you go into the fakie a bit more
Trails not Rails
Trails YT Channel
