So my problem is that, i Can't hop out of a 180, iv'e tried and tried the only thing i can do is pull the front tire around or roll out of it. When ever i try to hop out of it i end up falling of not being able to put my feet in the right position
To half cab out of a 180 you gotta kind of nose dive out of it.
When you're fakie, right before your cranks level out turn your bars slightly to get a carve going. then put pressure on your cranks and hop at the same time. Look over your shoulder like it's a regular 180.
It's really not that hard of a trick. Keep trying. If you're fakieing with your ass way over the back tire, don't. You should keep your weight right in between the back of your seat and the middle of your back tire.
