Double Pegs
3/17/2016 3:35 PM
I need some help balancing double pegs. I can hop on rails and get locked in but every time I do it I fall off over the rail, I don't know if I'm like on the rail wrong or if I just have shitty balance. Any advice helps.https://m.youtube.com/watch?v=vochI4km0Gc
3/18/2016 11:30 AM
Don't lean into it as much. Once you're on your pegs you need to keep your weight central and above the rail. You can lean the bike to help it lock in, but your weight should stay over the rail
3/26/2016 7:27 AM
Just go faster so you're weight doesn't shift over the rail as much when you've tiresome hit the rail.
