I always get about 270 . I'm not sure if it's me
Not commuting 110 % or not ?!
Get comfortable doing higher bunny hops. Swing your hips out too. it will add to your momentum.
Turn your head more too and spot your landing. I carve, hop, and turn my head looking over my right shoulder (I spin right regularly) or at my rear wheel. Make sure you are spotting your landing though and not just hucking. Spotting your landing also helps keep you more stable and on axis during the spin. Carving helps as stated above. Just remember to keep practicing because it takes time like most tricks. Recording yourself helps too if you are able to. If you haven't got them dialed out of a little bank or something similar, I recommend trying that first to get the mechanics down.
Edit: Damn, I just realized this was an old post that was bumped! Oh well, maybe it'll help others with this problem.
Winter is over-rated
Click here to check my ride
Turn your head more, compress before lifting the front wheel in the air, tuck your knees at 150-200
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
