Full Cab Help
2/25/2014 6:52 AM
my main problem is that i press out of a fakie oppo footed. whenever i go in a fakie i usually halfcab and do a little crank spin to go out normal, but cant press out normal. i can 3 and manual 180 so any tips?
2/25/2014 3:09 PM
Pivot on your back wheel half ways, then pop it the rest of the way. Your feet should go back to normal
3/6/2014 1:06 PM
Go with a nice speed. Turn 180 degrees, but harder, then care a lot and make the 360 motion. I landed a few today smile.
RIDE OR DIE
THE ROUTER
Instagram: Luislorentebmx
3/7/2014 8:29 PM
i do the same as u switch footed , its all in the hips applie pressure at 45 degrees then twist hips hard and lean back
3/7/2014 8:35 PM
Thanks!
