Fullcabs..
4/14/2013 10:23 AM
Edited Date/Time: 4/14/2013 10:27 AM
Hello ive been trying fullcabs for a while but im not even close. I can pivot on my back tire about 180 degrees but the wheel just drops and bhopping in that positionfeels weird... I need some tips guys. smile
4/15/2013 8:18 PM
Try to pivot even more on the rear and then once it gets past 180, put much more pedal pressure, pull in the direction and pop up the bike. I'm close to it too and I roll out switch-footed, so don't complain if you're correctly footed.
4/24/2013 7:32 AM
Learn manual 180s first it helps loads after that learn 540 taps them go onto the fullcab most of the movements in the first two are what you need to learn for the fullcab makes em so much easier to learn, and you won't get frustrated cuz you'll get em easy if you do what I say
Get some!!!
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
