HELP... Primo n4fl bearing replacement
5/14/2013 7:29 AM
Hi guys, currently caging the bearing but don't know how to put it all back together! Has anyone taken theirs apart then put it together? Should I put pne bearing on the axle first then hit it into hub, or put both bearings into hub the hit axle through? But then will that hit the other bearing back out? (Bearings Tight fit on the axle) Please help guys
5/16/2013 10:36 AM
ive never had one of these hubs but if you had a picture or 2 of the inside of the hub and bearings i could try my best to help
Go big or go home
