HOW TO 180
8/12/2014 10:20 PM
Read this before you ask. I hate people who always try and 180 but can't fakie.
LEARN TO FAKIE/ROLLOUT FIRST
Ride against a wall , do a nose press and lean back. As going backwards , turn about 90 degrees and then when you start to carve , pedal down to engage your hub ; it will make you go forward. The just pull up , twist your body and pedal back to regular. It's the hardest part of the trick , but if you practise you get it fast.
To 180 flat : Get off the computer and try it. Get bunnyhops comfortably , maybe like a foot off the ground. I can 180 flat with maybe a 4 inch hop , it's not hard. When you go to pull up , lean to the side so you pivot slightly towards the side your spinning , maybe like 20 degrees at most. Then , lean forward and bar hump and scoop your pedals WHILE looking over your shoulder : you might just go 90 degrees , which is good to get comfortable. But once you get past that , just commit and spot your landing. When you get good at them , you can basically fakie out of it as long as you get past 90. I learned flat 180's before flyout , which is the same concept just easier. If your doing it out of a quarter , seriously just fuckin turn in air , there such a lazy trick.
ITS NOT THAT HARD. So please go try , unless you are sickdude and fucking 90 to indian , just seriously go out and don't be a pussy. I can 180 flat , out of banks , into banks , over rails , up curbs , down curbs , sidewalk gaps , I learned nollie 180's first go. I have them dialed down 5 sets , it really isnt a complicated trick. Proof :
8/13/2014 10:14 PM
Annoying
13 years old
8/13/2014 10:18 PM
So many people ask , it's not like hop whips or nollie cabs , even the concept is easy. Like you dont NEED to look up how-to's for 180's . I've taught 10 year old kids to 180 in a day or 2 , it's not difficult
8/31/2014 9:19 PM
"don't be a pussy" hahaha this guy is inspiring
8/31/2014 9:42 PM
It's true , learning is ujst a mental game . Just put your earphones in , blast some metal and pedal at that bitch then hop like fuck and see what happens
8/31/2014 9:49 PM
the way i learned them after getting them on flyout was off a bench,
then off a smaller bench, then a big curb, a small curb, then flat
little steps make it waaaaaaay easier if you are stuck and cant get it for the life of you
9/2/2014 12:53 AM
Being goofy-footed, a pussy, and having OCD, it took me forever to learn these at first, but I have them down quite good now. It took me over a year to get them, and by that time, I had already completely dialed in fakies both directions. It also took me a while to get the feeling of doing spins off of a curb or something higher like a 2 or 3 set. I have tried a 4 set but I landed way too back heavy and almost fell on my back, so I'm not trying that for a good while even though I know I probably could.
9/2/2014 6:28 PM
how do you fakie?
9/2/2014 10:42 PM
tomdon wrote:
how do you fakie?
I see Tomdon doing them quick bitch crank fakies, lol. And are you joking or no? You can 360 to smith, and you can't fakie? That's ridiculous if true.
9/3/2014 7:28 AM
tomdon wrote:
how do you fakie?
isnowyaznV2 wrote:
I see Tomdon doing them quick bitch crank fakies, lol. And are you joking or no? You can 360 to smith, and you can't fakie? ...more
Just fucking with brayden. However, I do have a friend that can 270 bar, catches whips about 50% of th time, but successfully turns out of fakie only 20% of the time.
9/3/2014 3:16 PM
Krooked wrote:
Annoying
Agreed
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
