HUB HELP!!!
5/24/2017 2:57 PM
Okay so I cleaned out my hub today and re greased everything and put everything back where it should go and when I spin the wheel when it's not tightened to the frame it's spins freely and smoothe. But as soon as I tighten the 2 bolts to keep the wheel to the frame it's really hard to spin the cranks. I found that it's the last bolt that holds the hub on. This bolt gets tight when I pull the wheel back to tighten the chain and tighten the 2 bolts to hold the wheel in place. If I take the wheel back off the lock bolt and the bearing bolt (very last bolt) are a lot tighter. Please help this is very frustrating. this is all happening the drive side
6/24/2017 3:10 PM
your saying that hard to spin the cranks, is that because you need to regrease your bb or you got a really tight chain?
Trails not Rails
Trails YT Channel
