This headset install doesn't appear right. This is a Sunday Wave C and fork using a Odyssey (Campy) headset. Everything is tight (no binding) and no play/wiggle. All frames that I see the bearing is fully recessed in the head tube. These bearings extend about 2-3mm above/below the head tube. The bearings contact the head tube properly. Do I need to get an 1 1/8 headset that has cups (Mission conversion/recommendation) or thinner bearings? Bought used, don't know the year of the frame. Thanks for any help.
