Help with bars?
8/2/2013 9:03 PM
I was jumping dirt jumps with my bike and i bent forward so i just need to pull my handlebars back farther but when i try to unscrew the bolts on the stem it starts to break the bolt like wear down the inside part. should i just use a wrench or is there another way to do it?
8/2/2013 9:20 PM
you need to find a way of getting them out like using a hex socket, then after that you need to get new stem bolts, and to prevent your bars from moving again, put some tin foil around the treads of your bars.
MIDWEST MOTHER FUCKER
8/3/2013 8:32 PM
Your stem slipped, man. I had that problem, it sucks! It sounds like one of your bolts is stripped too! That's not good at all. I would recommend getting a better stem with your next order. I have an S&M Enduro and it's great! Most racing stems never slip and they're really high quality! Or if you don't get a good stem, don't land flat. Lol
YouTube
Instagram (@WillStockSucks)
