How do I tell if my headset is integrated?
12/25/2012 11:59 PM
HELP!!!! I'm kind of new to bmx, but can someone tell me what kind of headset I have? Is it integrated or standard? Btw my bike is a Haro f3 if that helps!
12/28/2012 12:03 PM
take your forks off, if the bottom bearing race is seperate it isn't integrated, if the bearing race is built into the forks the headset is integrated.
12/29/2012 7:54 PM
12/30/2012 3:48 PM
standard are open balls and integrated are solid berings
double murder suicide
12/30/2012 11:44 PM
Thanks im pretty sure its standard. Do you know if i can use a fork that was on a bike with an integrate headset on a standard headset bike?
12/31/2012 12:18 PM
cmtrippen wrote:
Thanks im pretty sure its standard. Do you know if i can use a fork that was on a bike with an integrate headset on a standard ...more
I'm pretty sure u will need to convert your standard headset using a kit. otherwise u need a frame with an integrated headtube.
12/31/2012 10:43 PM
incorrect
Latest edit (Check it out) | Anything With Two Wheels Goes!!
"Fuck it and Huck it" -Tomdon
12/31/2012 10:44 PM
Chris-BMX wrote:
take your forks off, if the bottom bearing race is seperate it isn't integrated, if the bearing race is built into the forks ...more
incorrect.
1/2/2013 11:37 AM
THAT. ^
1/17/2013 10:23 PM
its a standered headset and yes you can use a intergated forks on a standered headset frame i did it when i had a cult CC00
1/19/2013 11:07 PM
No you cannot, well your not suppose to.
1/20/2013 12:03 PM
Go to the review topic and go to "How to choose a Headset". There you got all the info.
