This is my hub, and I don't know how to adjust it. Anyone knows video where it is shown?
Quote
you have to tighten the drive side nut first, then adjust the non drive slack. make it a lil tighter than you want it cuz itll loosen up when it settles. Tighten your axle nut against the non drive side preload nut and back off the driver side preload nut, then set it, usually a little tighter than hand tight.
In midschool bike rides you.
