Need help with pedals
3/5/2017 8:54 PM
I have tried a 1/2 inch wrench and 9/16 inch wrench on my petals but neither of them are fitting, are those the only two sizes for pedal?
3/6/2017 1:54 AM
Edited Date/Time: 3/6/2017 1:55 AM
Dawson2272 wrote:
I have tried a 1/2 inch wrench and 9/16 inch wrench on my petals but neither of them are fitting, are those the only two sizes ...more
What I may have you wrong but the wrench for a pedal is a 17 15 mm wrench and then there's pedal size 1/2 is for 1 piece cranks 9/16 is for 2 and 3 piece cranks
I once walked into a gay bar it did not end well
3/8/2017 10:47 AM
^ that, you need a 15mm spanner. The " is relevant to the axles size
3/8/2017 1:10 PM
"Common" sense would dictate you use whatever size fits best. Some pedals take a 15mm spanner, others a 17mm spanner and some only take a 6mm allen key.
