Please Help
10/21/2012 1:08 AM
Ok this may seem really stupid but I went riding and cased on a ledge and popped the tire in two spots. So I just fixed it with a repair kit on the spot and kept riding. Then I did a 180 off the ledge and the tube popped again in like three spots. I run 2.3 United Direct tires at around 90psi. Does it keep happening cause the repair makes it weak or are the spokes pushing through and popping it.
10/21/2012 10:43 AM
have you checked all your spokes and your rim tape? Make sure there's nothing in your tire as well.
10/21/2012 11:34 PM
If you get a flat tire, don't cheap out and fix your tube unless that's your only option, better to get a new one. But if your tube is popping in several places make sure that theres nothing sharp in your tire, make sure your rim tape is good and that nothing is poking through it. Take your tire off the rim and look around at the inside of it for anything that could put holes in your tube.
10/28/2012 10:44 AM
try putting 2rim strips in if not just get fit faf they r awesome
