Primo Remix Locknut Issues
2/5/2015 7:39 AM
Right Hand Drive Primo Remix ( Non pro )
When i tighten the locknut on the drive side, if i spin the axle in the direction the wheel will move ( forward ), the lock nut loosens up a tiny bit, is that normal? If i tighten down the locknut a lot on the drive side, the axle won't move in the direction the wheel would spin meaning forward motion.
2/5/2015 11:08 AM
sounds a lil chewed up. go to your lbs and order new internals and bearings. should be an easy fix with fresh parts
