Rear Brake repair help plz!!!
7/28/2017 12:45 AM
Can someone help me with my rear brakes I bought and installed the cable but it still dosint work maybe I need to buy a cable for the handle I don't know someone help
7/29/2017 1:44 PM
I can't help much without pictures of it. Have you adjusted the spring tension of the brake arms?
YouTube can probably help quicker than we can
8/1/2017 8:18 AM
you need to have the cable pretty tight before you will be able to clamp down enough to stop the bike, and also the tension of the arms is important like he said. I think you adjust that by tightening the bottom nut thing with the spring attached to the correct tension, then tightening the bolt which mounts it to the frame.
