Rear hub bearings
11/24/2021 6:18 AM
Hi all, names Craig and just got back into riding after a ten year break. I picked up a fit pledge to cheap but needs new rear hub bearings, they are sealed. Question is are all rear hub bearings the same size? When I looked online to order some, let's say the profile ones, it says for primo wheels.
11/24/2021 6:27 AM
11/26/2021 12:24 AM
The code will be on the seal, take the cones off and you should be able to read the code. They're not all the same, but they all use standard sizes of sealed bearings
11/29/2021 12:37 PM
.pegless. wrote:
The code will be on the seal, take the cones off and you should be able to read the code. They're not all the same, but they ...more
Thanks alot, also I wanted to change headset bearings. Is it normal to have a sealed upper headset with and unsealed bearing at bottom?
