Rear triangle flex
6/10/2016 1:58 PM
Got a replacement used rear wheel (Halo MXR hub) with male axle. Went to fit it to my S&M BTM frame and there is around 1.5mm gap either Side between hub/dropout. Distance between dropouts actually measures at around 113.5mm
Would this need spacing or could the rear triangle flex to take up the difference without weakening the frame.
Hope I made sense, cheers
