Standard Bottom Bracket - stuck cup removal (need help)
8/12/2021 12:53 PM
I'm installing a new BB for a Shaun White Session 1.7 and the cups are giving me a very very difficult time coming off. I've hammering them using a screwdriver and a mallet to get them to budge from the opposite side of each cup and nil results. I did much research on the net and most of them cover another type of BB. Many thanks in advance.
CD
Bepis w/o vegetal
Thamks
Kalm
8/13/2021 10:02 AM
Try harder
It is not because things are difficult that we do not dare, it is because we do not dare that they are difficult: Seneca
8/13/2021 10:30 PM
Don't use a screw driver. Use a socket extension and a metal hammer. You can spray a load of wd40 or something on it first which might help. But a good hard tap should pop em out
8/14/2021 3:10 AM
Black Swamp Ghost wrote:
Try harder
More like "give it time".
Bepis w/o vegetal
Thamks
Kalm
8/14/2021 3:12 AM
UPDATE: PROBLEM SOLVED
Used a Dremel and a simple ceramic cutting disc and created a slot through each cup then used a mallet + screwdriver to finish the opening. Cups practically fell out. Thanks everyone.
CD
Bepis w/o vegetal
Thamks
Kalm
8/16/2021 9:54 PM
Used a Dremel and a simple ceramic cutting disc and created a slot through each cup then used a mallet ...more
Science!
