I'm going to learn 3s off a half foot kicker, any tips? I already know I need to turn harder than a 180 obviously.
Blue and gold white and green swag boi
Just make sure you actually hope a bit and buck the rear up a bit.
and if you are just learning them keep practicing even it you die a lot. another trick is to kind of look under your arm when you rotate, this will help you to not tire tap
Check this post out if you still can't get them! It goes through step by step. Although it is about bunny hop 360s, the principle is the same, you just need to go faster to learn them off something. Another thing, instead of learning off a kicker it would be easier learning onto the deck or a flyout.
http://www.weridebmx.com/how-to-do-bmx-tricks/bunny-hop-360-a-bmx/
