WHYYYYYY!
1/29/2012 7:02 PM
Edited Date/Time: 1/29/2012 7:02 PM
Even after tightening the compression bolt all the way, it eventually will get loose and from the stem down to the fork it moves.. LIKE WTF! lol I even have a spacer between the stem and the bolt.
[LINK TO IMAGE][LINK TO IMAGE]
PayPal Verified(;
REFs: 1of1547, Areansfsl, ScramHype, Lirider187, Blizzbikes, tito24 aka mom, ii Krxfted, Broughton, Bmx-junkie, Stoney Hawk
Shadow - Subrosa
1/29/2012 9:50 PM
Edited Date/Time: 1/29/2012 9:50 PM
you might need a smaller spacer. if that doesnt work try threadlock.
1/29/2012 9:53 PM
I don't need a smaller spacer. and my compression bolt is pretty long. The thing is, the bolt doesn't ever move but everything just gets loose.
PayPal Verified(;
Shadow - Subrosa
1/30/2012 11:27 AM
i get the same problem, i just untighten them both(stem and headset) and tighten compression bolt, then stem after, works
1/30/2012 2:56 PM
check if the stem is touching itself all the way around the steerer
1/31/2012 4:34 AM
the problem may be not enough spacers. the top of the stem has to be higher then the top of your fork tube, otherwise it wont compress.
if not, make sure you loosen your stem bolts before you tighten the compression
2/2/2012 4:35 PM
lol
2/2/2012 5:38 PM
gcomer13 wrote:
lol
you're an idiot lol.
PayPal Verified(;
Shadow - Subrosa
2/4/2012 2:36 AM
gcomer13 wrote:
lol
hahaha, retard.... I know what you mean I have the same problem but what seemed to work kinda(it took all day to get loose instead of like half an hour) was lock tight I put it on the steerer tube and the stem bolts =)
Cool Story Bro
