Will this affect frame integrity?
3/30/2013 1:08 PM
Edited Date/Time: 3/30/2013 1:08 PM
I have a fixer upper project on my hands, (2009? Kink Curb) and I was wondering if it would affect the frame's integrity if I were to cut off the brackets that hold the rear brakes. Would I only find a hole in the frame or are they simply welded on? Help?
A dyslexic man walks into a bra...
3/30/2013 2:21 PM
If you mean the brake mounts, You'll be fine cutting them off, You'll probably be left with a hole but that doesn't matter, a lot of frames have removable mounts, and when they're removed there is just a hole, so you will be fine.
3/30/2013 2:44 PM
Thanks.
