bending a warped sprocket back to normal?
9/28/2014 2:27 PM
Is this possible? My 25t sprocket is lightly bent, just enough that, if i run the chain tension that i like, it makes a grinding noise... so now i have to ride w/ a loose chain, or buy a new sprocket - or unbend this one.
I have a bench-mounted vice, pretty much any tool you can think of, i'm just not sure how to approach this cuz i think i may do more harm than good w/o knowing what i'm doing. I should probably buy a new sprocket cuz i want a stronger gear ratio anyways but $ is too low at the moment, so for now i'm riding a chain that's less.than.tight. :|
9/29/2014 10:51 AM
Get a Sunday Saber tooth for 30$ or a primo solid one for 25$
9/29/2014 11:24 AM
I can get guarded ones for $50 so will be getting one of those (knox, million dollar, magnum, etc) when I can but wanted to try bending it back in the meanwhile
9/30/2014 10:03 AM
you can give it a go... idk if itll work. I know people that have pounded em back to "normal" or as close as they can, just because they were broke and wanted ot keep riding until they could get something
skooter... dont be a pussy
10/15/2014 6:15 PM
It probably wouldnt be that hard to bend back, just make sure you heat it up a bit first or you could snap it, from memory sprockets are generally pretty brittle
10/15/2014 10:29 PM
If its aluminum you can simply use a malet and lightly hit it tell its straight to the eye..
Some will say to put it into 2 blocks of wood and tighten it in a vice
So whatever way floats your boat. Running a bent sprocket will cause added wear to your driver over time so I recommend a new one
Bike Shop Employed
5107766739 is my #
10/16/2014 10:27 AM
Some will say to put it into 2 ...more
yeahhh this. its just a temp fix until you have money for a new one
like I said, to keep ridign until you can get something.
