fork offset?
1/12/2011 1:47 PM
Can anyone explain to me what fork offset is? So confused...
420
1/13/2011 8:26 AM
Fork offset is basically the distance the axle sits from an imaginary line drawn based on the angle of the headtube. This is a road bike...but it does the job...
Essentially, more offset=slower steering, more stable ride. Less offset=more responsive steering, less stable ride. You will see zero offset forks out there which are used mostly for flatland because the flatlanders need the bike to respond the same whether the bars are facing forward or backwards.
Here's a zero offset fork:
Compared to a standard offset fork in which the offset (or "rake") is accomplished by welding forward facing dropouts to hold the axle, rather than integrating the dropouts straight into the fork as pictured above:
And here are the Odyssey Directors, which are still an offset fork, even though a quick glance might make you think otherwise. Instead of the offset being accomplished at the axle, it is created because the fork legs are angled forward from the headtube:
I hope that makes sense.
1/13/2011 9:03 AM
Man, you really do help everybody here out. Next time I have questions, I'm just going to come to you.
"I've had the 2 greatest corn dogs of my life, and I owe it all to BMX."
1/13/2011 10:26 AM
very well explained bro
pcoco ticaleb
1/13/2011 10:39 AM
Well I appreciate the praise, but it's not like I'm all-knowing. I know quite a bit of maintenance/tech, but if you have a question about doing tailwhips, barspins, or backflips, I'm definitely not the guy to ask. Besides that, there are guys on this forum who know just as much or more about maintenance/tech than I. Take Dave Lawrence. If there was any one guy that I would expect a good answer from on ANY question, it's Dave.
1/13/2011 10:59 AM
That makes so much sense! Now I can order forks without having to guess what offset is. Thanks man!
420
