ive been hopping for a while and i can now get about tire (20inches) now when i hop i feel icant get my front tire any higher and im stuck at 20 inches anyone know how from here ican get any more height
Keep practicing, find ledges, curbs anything that is a little bigger and start practicing using those. Really put a lot of effort into hopping higher. Not much other way I can explain it. Basically the way I learned to hop higher.
Brandon
Taylor
practice is all it takes, try hopping on to tables or over rails, helps a lot when there is something in the way.
Good luck out there
Build one of these out of a pallet you can do it on the cheap and its simple enuff, set the height levels 3 inches apart and move it up each time you clear it, you will be hopping bar height in no time, its wat I'm doin this weekend
dangerous thing.
to do a dull thing with style
without it.
Os 94
Ms 01
Ns 12
Soulrebelrastaman wrote:Build one of these out of a pallet you can do it on the cheap and its simple enuff, set the height levels 3 inches apart and ...more
thats a really good idea
Save a tree
