ok! 180 answer!
4/20/2010 11:55 AM
idk if this will help but go at a comfortable speed, pull up and turn at the same time then about 35-ish degree angle jerk your back wheel up then when you land backwards crank backerds! then turn out, fakie: when you first learn turn about 35 degree angle again when your turning around and press on your front pedal and turn your head which should bring your bike with you. hope that helps and if you want to half cab just barely turn on your fakie and hop and huck!
fuck trends
