taking pedal off
1/29/2015 7:36 PM
i have some cult plastic pedals and I can't get them off. I've tried a pedal wrench, dousing the contact point with wd40, putting my cranks in a vice. I'm going the right direction for each pedal but they won't even loosen. any ideas?
2/3/2015 2:08 PM
pour some boiling water on it or use a blow torch to heat it up lightly. when metal heats, it expands. this will hopefully cause the seized threads to separate from eachother. then use a big honkin cheater bar on the end of your pedals wrench for extra leverage.
3/16/2015 5:37 PM
Use penatrating oil it works much better than wd40 I've used it multiple times on my bike when I couldn't get it undone. You can also try using a wrench with a longer handle it will give you a lot more leverage
5/24/2015 6:06 PM
Take it to a bike shop
