Painting Parts
4/30/2016 8:32 PM
Edited Date/Time: 4/30/2016 8:55 PM
so started off with an 02 ZX7-R (Ninja 750) it was spray painted drips all over it had duct tape and stickers that had been clear coated over and pin stripping.
i decided to finally start stripping my bike and painting it getting it looking all nice .
[b] i decided just to do it by spray can because im good enough to get away with it so this is literally what i am using.
so started off with some aircraft stripper, brushed it on let it peel
then i hosed off the majority of crap that came off and sanded the metal down smooth using 120 grit, once done with the sanding i wiped off the dust and then used rags soaked in denatured alcohol (ethanol) to get off any residue and left over dust.
ethanol dries quickly so chilled out for couple of mins and then sprayed the primer, 4 coats in.
then i sanded the primer any high spots or containments / dirt using 400 grit.
after sanding wiped it down with more ethanol and then the basecoat, started off light and even
after 4 coats of base i let it all dry overnight and then proceed to the clear coat
and once that was done here it they are with clear coats on, but they need to be wet sanded and even'd out a little more had couple of runs in the clear so ill take em down and make it shine like issac hayes.
will be posting more after i wet sand and get it all polished and ready cant do it till its fully cured, painting aint rocket science just take your time have a smoke or whatever and kick back just work clean
5/1/2016 7:08 PM
Nice bike man. Paint looks good.
FBM Pizza Beer Roast Machine
5/1/2016 9:27 PM
thanks it was this or having a laird frame built and custom bars.
i have a lot to do on this figured id do some painting while my broken arm heals.
this bike will express its japanese heritage, hence the white lol
5/3/2016 10:39 PM
i have a lot to do on this figured id do some painting ...more
Rising sun or gtfo haha
5/4/2016 12:12 PM
im actually getting decals and stuff from japan.
for the tank protector that goes on it to protect the tank on the crotch region
