help with home sound systems :)
11/23/2011 5:50 PM
does anyone know if i have a 600 watt stereo but have 720 watt worth of speakers going into it is it bad overpowering the system or what smile
"scooter are gay 20inch all the way"
11/23/2011 8:50 PM
no your fine
11/23/2011 8:51 PM
if it was the other way around it would probally be bad
11/23/2011 10:01 PM
U may damage the speakers. U can more likely cause damage to speakers under powering them
Trails not Rails
E21 - Resto + E30 340i M60 v8 build + E36 328ti Daily skidder
11/23/2011 10:33 PM
ok sweet thanks for ur help man smile
11/24/2011 11:20 AM
you cant damage your speaker by underpowering them, thats a myth
11/24/2011 9:55 PM
Most speakers get blown from being underpowered its not good for them ask at your local audio place they'll let you know me and my buddies have been hooking up car sound systems for time
11/24/2011 11:14 PM
its not a myth, i live on dub jungle and drum n bass and am learning to mix. i need to know about speakers and sound system setups. its not a myth heres an eg.
3 litre car, 1 litre car. drive round a track at 80? mph constant. the 3 litre car will handle it easy, the little car might be worn or burned out because its being over worked. its like that with speakers. if u try and over work the speakers with in sufficient power its gunna blow
Trails not Rails
11/25/2011 9:04 AM
the only reason people blow there speakers is because they send clipped signals to them. and what you were saying was true then every time you lower the volume they would blow.
11/25/2011 9:05 AM
volume and power arnt linked directly
Trails not Rails
11/25/2011 9:10 AM
every time you turn it up you your askin the amp for more power
11/25/2011 9:18 AM
no matter how loud it is. the driver needs to be able to move the speaker. the more wattage a speaker is, the bigger it is. if ur trying to move a 12 inch sub thatrs 700w with 500, the driver is being over worked thus blowing the driver
Trails not Rails
11/25/2011 9:19 AM
http://www.totalsounds.co.uk/images/s5000.jpg whatever im ordering these for my room
Trails not Rails
11/25/2011 9:22 AM
yeah overworked which means sending a clipped signal
