A popping sound comes my bike when I peddle hard
4/11/2016 12:18 AM
I can't seem to fix the problem with my bike so about every other peddle I do my chain or my rim or what ever makes a loud popping noise an I can't seem to solve the problem with it any suggestions
1/7/2017 5:09 PM
Preston_Villalobos wrote:
I can't seem to fix the problem with my bike so about every other peddle I do my chain or my rim or what ever makes a loud ...more
Its most likely your chain line! But could be a number of other things as well.
1/7/2017 7:20 PM
You might've blown a bearing somewhere. I ran a pedal with a bent spindle and destroyed bearings once and it popped all the time, it wasn't fun.
4/16/2017 8:17 AM
Mine does this too but I use a masterlink on the chain, and it pops when the masterlink is torqued because it's a bad one. Also your sprocket might be not straight with your cassette or your sprocket might be crooked.
5/1/2017 1:06 PM
Take off your front sproket and lay it on a flat surface and see if its bent even slightly and if so get a thicker aluminum sprocket or a chromoly sprocket they are more durable
