Chain tension
9/22/2015 2:21 PM
Hi,
Since two weeks the tension of my chain change with the position of my pedal.Is that because my front sprocket is twisted?
9/25/2015 12:21 PM
Do you mean the tension changes when you move the pedals?, like one spot is tight then half a crank it will become loose. If that's not what your talking about sorry I don't know, but If that's the case your sprocket may just be on too tight or on unevenly.
9/25/2015 7:39 PM
Yes that is what I mean but the chain early cant enter in the rear sprocket teeth even if the chain is not that tight is that might be my chain that is stretch?
