Correct brake rotor
12/28/2017 9:29 AM
So I bought a 2014 haro steel reserve 1.2 from a friend and it has tektro I/0 mechanical disc brakes but the rotor is all bent. It’s a 6” rotor or roughly 152 mm. Now would a 150mm rotor be a good replacement and a correct fitment because I can’t find 6 inch rotors anywhere
12/28/2017 9:50 AM
Go to a bike shop or bmxmuseum
Hmmm
12/28/2017 10:17 AM
Figure out what came stock on it, and find a match, or replace the brake with something new.
If it is only a little warped sometimes grabbing the brake at the worst part when the wheel is spinning can "unwarp" it a little.
12/28/2017 12:41 PM
Edited Date/Time: 12/28/2017 12:42 PM
It should say what size it is. It'll be in mm. 60mm is the most common, and it's usually 20mm increments (40mm, 80mm, etc). If it's post mount you can adjust the caliper with spacers if you really need to though
1/9/2018 4:14 AM
I bet its a 160. Haro lists it as 6" which is 152 but thats a weird number. I bet if you took it off and brought it to a lbs they can match it.
