How do I use an eclat maverick crank tool?
1/5/2017 6:42 PM
No bike shops near me and i want to install/remove my cranks.unsure
1/6/2017 12:46 PM
To install, you take everything off the tool, so it's just the big part. Get your cranks on as far as you can push, then thread the tool into the bolt hole in the axle and tighten until your crank arms are on as far as they can go.
To remove, put all the bits of the tool back together, take your crank bolts out, thread the wider part of the tool into your crank arm, and tighten it. Then tighten the main part of the tool. The main (longer) part will push against the axle, pulling the crank arm off the axle
